Steering stem
Old Sep 26, 2003 | 11:05 AM
Burnie's Avatar
Default Steering stem
Any one know where I can get a stock steering stem fast?? I need one in atleast 2 weeks.
Old Sep 26, 2003 | 02:48 PM
Gaskett's Avatar
What's wrong with yours?
If your tube is bent, just take it to a welding shop and have them replace the tube. That's what I did and it only cost $35 (labor and the metal). I had the tube lengthend by 1 1/4" so I can use Renthal bars and not have them hit the tank.
Make sure the tube they use is the exact same size.
Glenn
Old Sep 26, 2003 | 03:53 PM
Burnie's Avatar
Its bent pretty bad
Old Sep 26, 2003 | 04:52 PM
dsracer666's Avatar
www.quadpro.ca
Old Sep 26, 2003 | 05:34 PM
Gaskett's Avatar
It doesn't matter how bent it is, the shop is going to cut the old tube out and put a new tube in.
The handle bar plate and the tie rod plate on the bottom are welded to the new tube.
It's A WHOLE LOT cheaper than buying a new stem. And having a machine shop do the work, you can have the stem custom made to the length you want.
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
