PLEASE HELP!!! Water sucked up in cold air intake HELP
I'd really love some help on this one guys!! I sucked water up through my cold air intake on my car going through some water, The car seems to run fine, but the engine is knocking quite a bit, is there anything I can do??? Any suggestions?? Please!!!!!!!!!!!!!!!
The engine seems to run fine though, do you think it is still toast? I mean I've driven it for a while, can't seem to find any damage other than the knocking noise.
dang, that sucks. my guess is it mooshed the rod bearings and they gradually got worse with their new free play. Im just guessing though lol, I dont know alot about messin up car engines, I been sticken to messin up quad engines. Should check your airbox though to see just how much watter it sucked up.
Thanks for all the optimistic help guys!!!!!!!!!!!!
Any engine that really gets a load of water in it typically has at least a couple of bent rods. Actually you probably didn't get too much water in the cylinders because it's still running! I've seen engines flat come apart after a little deep water diving!
have u changed the oil since running her throught the water. this could buy you some time. or it could cure the knock. depending on how much water and where the water went could be the big factors on the knock. does it seem to be top/ or bottom end?
justin
justin
Friend of mine said it sounds more like a valve tap than a knock, sounds like a tltltltltltltl, almost like a baseball card against the spokes of a bicycle. Any ideas guys. Oh and yeah I changed the oil. Still makes the noise
