PLEASE HELP!!! Water sucked up in cold air intake HELP
Old Sep 29, 2003 | 10:23 PM
Badshee98's Avatar
Default PLEASE HELP!!! Water sucked up in cold air intake HELP
if it wasn't making the tapping noise before you went through the water, then you can pretty much rule out your valves being out of adjustment. is the knocking REALLY loud? sounds like someone beating on the bottom of your car? your idea of loud and ours may be a bit different. you need to try and isolate where that noise is coming from- top of the motor(valves) or bottom(the expensive side)
Old Sep 29, 2003 | 11:12 PM
Blaster96's Avatar
Sounds like you bent a valve or threw the piston out of wack. That cold water commin in on a hot metal part can realy warp the crust outta stuff... Dont drive to farm from home and keep a cell with you... Buy a 4x4 and that problem disapears on the street, but gets worse in the local mud pit....
ultangler
Nov 30, 2024 01:35 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
