650 Cat or Polaris 700?
Old Sep 28, 2003 | 04:07 PM
Copper990's Avatar
Default 650 Cat or Polaris 700?
I am thinking of switching to a Cat 650 or 700 Polaris. I have a 650 Prairie right now, love it but want more ground clearance. I have had several Polarises and have had good luck with them, with the exception of a 700 that had a slipping belt - chronic problem. The 700 was a very early model and I think it may have just been a lemon. Other than that I liked it, also thought low range was too low. The 700 is cheaper and I have heard they are much better with the heelclicker installed. What do you guys think? pro's con's? Please no brand bashing, just helpfull info in comparing the two. Thanks!
Old Sep 28, 2003 | 07:12 PM
Bluethumb's Avatar
Hi, I would personally go with the AC 650, its' drivetrain has been proven by Kawi and the chassis by Arctic Cat. I would caution against the Polaris 700, just because of some problems they're having with the motors. Go on the Highlifter.com site and read about the bad rod bearings in them. I'm not bashing Polaris, it's just a quirk that they have to work out. I don't know if the Polaris 600 is the same, but I think it's based on the same engine design. Just read that, you'll get the gist of it. As for the AC 650, nobody has one yet, so I can't comment, it'll have to prove itself alongside all the other bikes out there. You obviously know about the Kawi engine, so that part should be convincing enough,
Old Mar 8, 2004 | 06:14 PM
Tooleman's Avatar
HONDA RINCON 650 i bought an 03 and i have 2500 on it already and it aint easy ridein i 17 and ride with sport quads and i never last. If you want durable Go honda
Old Mar 8, 2004 | 06:16 PM
Tooleman's Avatar
I never in last position ridein***
Old Mar 9, 2004 | 12:42 PM
jenjabber's Avatar
I agree. I have the 650 LE and have a friend with a Kawa. 650 and one with a Kawa. 700. The 700 is a 2004 and his is now selling it to buy a AC 650. Better ground clearance and better ride suspension.
Old Mar 9, 2004 | 10:42 PM
FluxGhost's Avatar
I am (1) month and 150 miles into my AC 650 and have yet to regret it for a moment. I have noticed other guys going around obstacles that I just straddle.
My 2 cents,
Flux
Old Mar 9, 2004 | 11:09 PM
cat5004x4's Avatar
personaly I would go with the cat. Bought the 500 and I have a freind with the polaris 700 and I'll take mine places that he will not even try. but there all good machines. and you can't go wrong with either one
Old Mar 10, 2004 | 09:58 AM
AC650's Avatar
You have a Arctic Cat 650 listed under your name. Have you already switched? If so, I think you will be happy with your decision. Either way when you get into the top end machines from any manufacturer you will probably be happy with any of them.
Old Mar 10, 2004 | 05:22 PM
Tooleman's Avatar
HONDA 650 RINCON!!!!!!! cat should stick to sleds my dad have one he hate it its in the swap sheet now for sale it a 500 its only 2 yr old and makes weired noises hooked up to it wit the rincon lol no match
Old Mar 10, 2004 | 07:15 PM
Bluethumb's Avatar
Your eyes are brown kid. Put the Cat in low range, 1st gear, and hold it down, it'll pull that rincon without sweatin'. Rincon's lighter, higher geared, it's not meant for pulling. Cat's geared lower too.
