Progressive Suspension Install mistake
Old Sep 29, 2003 | 12:11 AM
Parker650's Avatar
Default Progressive Suspension Install mistake
After putting the new springs on one of the struts, we replaced the c-washer at the top of the strut but didn't put it where it was supposed to go. We put it on top of the actual stop that we were supposed to put it and the top of the strut. The pressure of the spring sliced the rubber boot that seals the underside of the ball joint at the top of the strut, oozing grease. I slapped a bunch of grease on it and am going to leave it.
I am 99.99% sure that Kawasaki doesn't sell this small boot and I have no idea how you'd replace it as it doesn't seem like the strut comes apart at all.
Thats all...anyone attempting the progressive spring install, get a strut compressor or get 3 or 4 big guys to help. Get a rope, and pull the springs down to get the c-washer back on.
Parker650
Old Sep 29, 2003 | 06:28 AM
therock's Avatar
I have used 3M contact cement to fix a rubber surround on a 12" subwoofer that a screwdriver went through. Alcohol around the cut and put a coat over it. Then use a needle fitting to refill.
Old Sep 29, 2003 | 04:01 PM
Parker650's Avatar
3M cement...thats a good idea...I'll have to try it. Only problem is getting the grease that I slapped on it off....Anyone have a syringe?
ReconBayou
Oct 31, 2022 05:37 PM
Robinhood
Dec 26, 2015 10:28 AM
2many2ride
Sep 27, 2015 04:35 AM
black_thunder
Sep 7, 2015 01:24 AM
