another belt question
Old Sep 29, 2003 | 06:50 PM
azpooch's Avatar
Default another belt question
I know these belt issues can get long in the tooth. I have a friend who has a SP500 HO. He got into deep water, got it out ran fine. Started to act up on him a few rides later. He changed the belt himself. I dont think he has a manual. Is it a strong possibility he installed the belt wrong on the cheves? Im a 2 wheel guy in a 4 wheel world. Just tryin to help out a friend and gain some knowledge for my self. Thanks a bunch!!
Tony Pucci
azpooch
Old Sep 29, 2003 | 06:56 PM
azpooch's Avatar
One more thing to add. He was only able to get the SP500 up to about 35 MPH max. There is nothing wrong with his carb. When you use the thumb throttle, it will get up to speed quick, but will max out at 35 MPH. Not sure if he reinstalled it correctly
Thanks again
azpooch
Old Sep 29, 2003 | 09:51 PM
Farmr123's Avatar
The belt will fit either way. Did he get mud in the belt housing? Rinse everything off good with water, and check the rear pulley for binding.
Farmr
Old Sep 29, 2003 | 09:56 PM
fishslab's Avatar
I have to go with farmer. Sounds like crud in the pulleys.
Old Sep 29, 2003 | 10:57 PM
DustinMinnesota's Avatar
If I am a betting man I bet he has worn the thrust washer in the clutch. Check for teflon shavings or brass shavings.
Old Sep 30, 2003 | 06:05 PM
azpooch's Avatar
One tech at a local shop said it could also be a clutch problem too. Are they an easy R&R. And are they expensive??
Thanks [img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 30, 2003 | 06:16 PM
depends as the clutch is easy to work on but a bear to tighten the spider if you do not have the proper tools. If you have a good shop get them to give you the installation instructions from an EBS clutch installation it shows you the clutch blown up and the proper torques for the clutch.
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
stcspiderman
Sep 13, 2015 05:15 PM
Logan Collins
Sep 5, 2015 08:03 PM
