Cant hit the limiter
Old Sep 30, 2003 | 06:33 PM
Bajaboy650's Avatar
Default Cant hit the limiter
Alright guys I am a Big guy, around 325 lbs. Just wondering if there are any others out there that weigh close to what I do. If so , can you hit the rev limiter in 5th gear. My bike has an endcap, jet kit and k&n filter, and at top speed it will sit right between 7900 and 8000 rpm. I also and running 22 inch razr2 on the front and 20 inch razr on rear.
Old Sep 30, 2003 | 08:45 PM
RoughRider01's Avatar
Im running pretty much everything you got. I weigh 160 lbs, i can hit the rev limiter pretty easy. One day i had my buddy on back cuz he would jump off at certain points then camcord me. With him on it i could not hit the rev limiter in 5th, maybe i could have but i would needed a very long ways to hit it. Im guessing us combined were around 340-350, hope this helps
RoughRider01
Old Sep 30, 2003 | 09:30 PM
HIB650's Avatar
No, not really I have done it at the dry lake but barely in regular dirt or sand no way
Just changed to a 15t front so probably can now. My buddies that are around 250 can but i cant ( 325ish also )
Old Sep 30, 2003 | 10:20 PM
ironrod's Avatar
I'm 250 lbs and I am down to a 14 tooth on the front and a 40 on the rear. The Vortex CDI rev limit kicks in at around 9000 RPM and the GPS says I am going 74 MPH. I hit it pretty quick. The gearing calculator says the speed should be 77 MPH, but I suppose the difference is the actual size of the shaved tire.
Old Sep 30, 2003 | 11:59 PM
Bajaboy650's Avatar
Thanks guys, was just wondering if maybe something was wrong. Oh wait something is, Im 325 lbs!!! haha
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
