ds 650 no fire?
Old Sep 30, 2003 | 10:32 PM
poacher's Avatar
Default ds 650 no fire?
hi im very new here and i just bought a 2000, ds 650 yesterday for 2150, the reason for so cheap was it had no spark. i did a compresion check to be sure it wasnt all wore out and it was 128 the dealer said anything over 100 was good. now what are things i should check? i looked at the back of the machine and see the i assume the voltage regulator and the red wire was broken off and when i hook it it made no diff you couldnt tell it was broke cause it almost was together but the other ires was holding close to it. i myself think if that red wire was to be regulated and wasnt it must of fried the cdi or the coil?i turned the key and checked for spark and also power to the coil and nothing. i check the ingition switch and im going chase those wires also. any one had this kinda of prob ? and where can i get these parts cheap for a 2000 ds 650 i know nothing about them but ive heard all good thank you
Old Sep 30, 2003 | 10:39 PM
SANDMAN430's Avatar
it's a long shot but there is some wires that come out of the stator side if you look at the heat sheald you will see a couple of disconnects in there, make sure there both connected, if there not no fire there are also a few fuses to check under the seat.
Old Sep 30, 2003 | 10:47 PM
poacher's Avatar
thank you ill be sure to check it out that would be nice if it would be that easy.
Old Oct 1, 2003 | 10:44 AM
SANDMAN430's Avatar
it was for me once, hope it works for you.
Old Oct 1, 2003 | 07:10 PM
poacher's Avatar
Originally posted by: tbrproducts
your cdi box is bad they go out alot
thanks im going to get one anyhow to upgrade if they offer the higher rev for a 2000
Old Oct 1, 2003 | 11:13 PM
SANDMAN430's Avatar
i haven't heard of a lot of bad cdi's.
Old Oct 1, 2003 | 11:40 PM
TyreSpinner's Avatar
me either
Old Oct 2, 2003 | 12:17 AM
poacher's Avatar
is there a way to test cdi boxes? and the other electrical units if it isnt something simple
Old Oct 6, 2003 | 10:05 PM
poacher's Avatar
hey got it going it was cdi box thanks for the help
Old Oct 6, 2003 | 11:02 PM
SANDMAN430's Avatar
it was the cdi? that is the first i've heard of that.
