V-Force FAQ's on springs, clutching, pipes & jetting
Old Oct 4, 2003 | 12:50 AM
KevinM's Avatar
Default V-Force FAQ's on springs, clutching, pipes & jetting
This is a compilation of the dozens of private messages I've received since I started modifying my V-Force. Maybe it can help cut down on the same posts that come up over and over each day.
V-Force Frequently Asked Questions
Old Oct 4, 2003 | 01:03 AM
Doctor1's Avatar
Thanks Kevin good info
What do you have on the coolant hose in that one pic is it a filter? or something to protect it?
Old Oct 4, 2003 | 02:12 AM
Bigsaint's Avatar
Very useful, thanks Kevin !!
Scott W.
Old Oct 4, 2003 | 02:12 PM
MacV700's Avatar
Thanks for the good info.....................
Old Oct 5, 2003 | 10:19 PM
KevinM's Avatar
That's a CFM inline cooler. You put those inline in your hoses and they're supposed to lower the water temp a few degrees.
Old Oct 6, 2003 | 10:56 PM
Kawy's Avatar
Thanks Kevin for the great info! You have been a great help since the beginning.
Old Oct 7, 2003 | 12:06 AM
zmann's Avatar
Good info. Thanks a bunch.
Old Oct 7, 2003 | 02:42 AM
mjohnson97045's Avatar
You write about launching the V in a Drag but I am still a little confused. Is it like brake torqueing an auto car?
Will this wear out the belt a lot faster?
Old Oct 8, 2003 | 11:31 PM
RocketJoe's Avatar
Kevin,
"I have settled on the HPD plain 32/235 with 3 shims as the best combination"
Do you have a part # for your 32/235 springs form HPD. I could not locate them on there web site
www.hpd-inc.com
The part number for a shim is Kawasaki part # 92026.
Thanks
P.S. Nice job on the FAQ
Rocket
Old Oct 9, 2003 | 12:14 AM
KevinM's Avatar
That's something I'm going to have to make a note of. HPD uses a different measuring system than everyone else. The 32/235 is the rating to use to compare to other springs, but they are listing it as 55/216. HPD6 is the part #.
