Another jetting question..with a twist
Old Oct 4, 2003 | 06:26 PM
whatwasthat's Avatar
Default Another jetting question..with a twist
Alright, here's a question for you jetting guru's... 440, 11.1 weisco, with a hot cam stg 2 and stock exhaust and stock carb with a k&n...
Any takers? lol
Old Oct 5, 2003 | 01:32 AM
duneittilludie's Avatar
your 440 is basically the same set up as my wifes except she runs a fmf q muffler and header and we have tried many different mains and we have settled on a 175.i would think that with the stock exhaust that you would probably need a 160 or possibly a 165.our jetting is set up for sea level so yours may be different in that regard, also we have also found that a mixture of 1 gallon of 110 octane race fuel mixed with 4 gallons of 92 premium pump gas works very well with the 11:1 compression and a midrange cam so you may want to try that combination.these are just my opinions, but you did ask.good luck
Old Oct 5, 2003 | 12:51 PM
cals400ex's Avatar
i am running a similar setup as you but my compression is a little higher but i am only running a 406. i also have a full exhaust. i have been trying to figure this out for a while since i am really particular on jetting. i tried a 165 first and the bike ran good. i put in a 162 and the bike was better. i put in a 160 and that was the best of the 3. now, i jet my bikes for best performance. i know you don't want to be lean. some people put in 175's or so and i know their bikes would be faster with the smaller jets. most just don't want to run lean so they put a bigger jet in where the plug looks like a nice tan or brown color. the rich setting will make the bike run cooler. i am just telling you a smaller jet will make your bike be faster to an extent. i was recommended running a 155 with my setup but i am going to put in a 158 to be on the safe side. good luck
Old Oct 9, 2003 | 10:44 PM
are you guys talking d/j or mikuni? Finally going to break it in on saterday.
Old Oct 11, 2003 | 06:19 PM
ttt, didnt break it in yet..
Old Oct 16, 2003 | 02:19 AM
cals400ex's Avatar
i say a 155 or 158 main at biggest. bigger doesn't mean better unless you need it. use keihin jets. we have a keihin carb. the dynojets numbering is different and you will have to pay for the whole kit. just get the individual jets.
Old Oct 16, 2003 | 06:50 PM
well, i already had the dj kits, i ended up running a 160 d/j a dj needle on 3rd groove and stock pilot, it pulls good considering the stock exhaust
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
