400EX big bore kits
Old Oct 5, 2003 | 11:05 PM
CroBiker's Avatar
Default 400EX big bore kits
i have an 00' 400EX and i'm looking to get it bored out to a 440. i don't race, i simply want more speed and power. i have a new exhaust pipe. i'm looking for a basic big bore kit. what company should i go with? i don't have too much money, somethin under 600 bucks is nice...the cheaper the better. thanx.
Old Oct 6, 2003 | 12:04 AM
420EX's Avatar
LOOK ON EBAY RIGHT NOW!!! THEY HAVE A 440 BIG BORE KIT GOING FOR $165, JUST GO TO EBAY.COM AND TYPE IN "HONDA 440 BIG BORE KIT" AND YOU'LL FIND IT
Old Oct 6, 2003 | 12:26 AM
CroBiker's Avatar
kool, thanx. is ur quad bored to a 420? how well does it preform?
Old Oct 6, 2003 | 12:33 AM
420EX's Avatar
nah, 420 has nothing to do with my quad, lol, but im gonna get it bored out to 440 whenever i completly wear out the stock bore, the only thing bad about the 440 kits is that once you et it bored to 440, you have to get a whole new 440 kit everytime you rebuild the top end because there is no oversize 440 pistons so if you hve the stock bore and its still good, dont mess with it until its worn out unless you like spending money
Old Oct 6, 2003 | 01:42 AM
thunderalley400ex's Avatar
Cro,
If I was you I would save up some more money and get your motor built right the first time insted of having a lot of problems because it wasnt done right the first time. After you save it is best to have one company aka Sparks, Ct, Lrd do all the work so it is reliable and if something goes wrong you know there was only 1 company that worked on your quad and you can take it up with them. Also when you do get the 440 I would reccomend porting, cams, high quality piston (11:1 or 12:5:1) compression should be good for the dunes and some of the other goodies. Trust me do it right the first time so u dont have to do it again!
good luck
Old Oct 6, 2003 | 02:04 AM
CroBiker's Avatar
awesome, thanx for all the info. i have one last qestion tho...do u know what the stock compression is for a 400EX? i run premium pump gas (i fogot what octane that is, i think it's like 91 or so) would that work with an 11:1 compression ratio? that is the most common ratio that i've seen.
Old Oct 6, 2003 | 02:17 AM
Im pretty sure you can run pump gas, on my dale its a 12:5:1 compression but relly like 11:9:1 and I run 91 in it with no problems. Oh yea i think the stock compression is 9:6:1 or something close to that. But with the 12:5:1 you will have to atleast run half pump half 110 but you will get more power...
Old Oct 7, 2003 | 12:28 AM
CroBiker's Avatar
instead of mixing gas, could i jus add octane boost? also, where can i get a 416 kit, i think that might be better suited for my needs.
Old Oct 7, 2003 | 01:29 AM
About the octane boost you can run it if you wanted to but I wouldn't reccomend it. Cirten adactives in there that the motor doesnt agree with. You could go to sparksracing.com for info on your 416 kit which I think they make the fastest 400's around or ctracing.com i think and look for ldr also...
Old Oct 7, 2003 | 10:57 AM
Ds650RaCeR's Avatar
im running a wiseco 440 kit,hot cams stage 2,port and polished head,11:1 high comp piston,FCR 39MM carb on meth...and i love it!it outruns my Stage 3 Ds650
