scrambler 400 noise???? please help
Old Oct 6, 2003 | 01:21 PM
gblair70's Avatar
Default scrambler 400 noise???? please help
I have a scrambler 400. When i am just sitting still my belt or cluth seem to be hitting the cover. When i give it a little throttle it doesnt do it. I put another belt on and it is still doing it.. I tried to adjust the cover and it still is doing it. Please help
Old Oct 6, 2003 | 02:49 PM
savage21's Avatar
Hello GBLAIR70,
Step 1. Take your Clutch Cover off,check for the cover for rub marks,next,check you clutches, turn the quad on crank it up watch you fingers and toes b/c the clutches are moving,if you don't hear the sound anymore ,then its not your clutches its the clutch covers.
Step2.Go to your local Polaris Dealership{call first} tell them you want a new clutch cover,For a 2003 400 Trailblazer. Why a TrailBlazer 400 clutch cover you may wonder, B/c the TrailBlazer 400 Clutch Cover is made of a better plastic and will withstand alot more heat than you factory Scrambler 400 Clutch cover will,Now you can get a factory Scrambler Clutch cover to,but it won't fix the problem, Also with the TrailBlazer 400 Clutch cover its the required to change the Clutch Cover Vent ,Which is alot bigger therefore letting more Cool Air in and Hot Air out of you clutches. The clutch cover and the clutch vent from the trailblazer is very easy to install it the same way as the factory one came off the only thing you have to do is take the factory Clutch vet off and replace it with the New TrailBlazer 400 Vent,which the bolts match perfect,
Step 3 Its a also while you have your clutch cover off is to get a new gasket to keep the water out,{gasket atwwhich goes around the inter and outer clutch cover.{all you need is the Outer Clutch cover} and it also a good idea to change the belt since you will be having it all apart.
Step4. Ride Safe.
This should help
Old Oct 6, 2003 | 02:58 PM
gblair70's Avatar
I appreciate the help. My 400 scrambler is a 97 is it ok to get the cover for the trailblazer in that year or new?
Old Oct 6, 2003 | 05:43 PM
savage21's Avatar
Yes,And you can look at them both at the the dealer TrailBlazer Verse the factory Scrambler And you can tell which one is tougher..just by the texture in the plastic
Old Oct 6, 2003 | 05:52 PM
savage21's Avatar
If you need any other help,you can PM me. I don't know much about the scrambler,b/c i haven't had mine long,but i have been threw the clutch cover problem,
Old Oct 6, 2003 | 06:23 PM
ftwflh's Avatar
If a few bucks aint going to hurt you get a cover for a new Trailblazer 400 it comes with a drain and is thicker.And I too think you need a cover.
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
Matt123
Sep 29, 2015 01:29 AM
Ahtatu
Sep 28, 2015 12:14 PM
