tm48 or vectron 46 ?
Old Oct 6, 2003 | 08:46 PM
thebigshow's Avatar
Default tm48 or vectron 46 ?
just wondering which is better on the perfomance side of things. plus does anyone know how much each of them cost.-im getting ready to upgrade my carb and dont know which way to go.
Old Oct 6, 2003 | 09:01 PM
SANDMAN430's Avatar
if you plan on stock engine on the inside i'd go the lectron, if you ever plan big bore i might go 48mm
Old Oct 6, 2003 | 09:45 PM
CountryJoeGlass's Avatar
thebigshow I would go with the Lectron 46HV carb!
Old Oct 6, 2003 | 09:47 PM
ironrod's Avatar
I'm pretty sure you can get an untuned TM48 pretty cheap. Under $400
Old Oct 6, 2003 | 11:38 PM
DuneDevil's Avatar
Between these two carbs, I would recommend the 46HV for a stock to a stage 3 running trails and playing. The thumb pull will not hurt you after 2 or 3 hours of rideing. And it has great response all the way through the power band.
The TM48 I would recommend to the serious drag racer.
This is just my opinion, and don't want to start a flame war.
DuneDevil
Old Oct 6, 2003 | 11:48 PM
ironrod's Avatar
I dont believe you can run the TM48 without the twist.
Old Oct 6, 2003 | 11:52 PM
thats why I like the Lectron 46HV, I want the thumb throttle & not the wrist. "IMO"
Old Oct 7, 2003 | 12:22 AM
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
The TM48 is just like the TM45. Thumb or twist will work.
Old Oct 7, 2003 | 12:24 AM
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
Just to confuse you a little more, you could also think about the Lectron 48HV or the 50mm straight bore, although I think the 50 would take some serious intake modifications.
MrHorsepower
Old Oct 7, 2003 | 01:07 AM
thebigshow's Avatar
thanks guys- does any one know how much the lectron cost tuned?
