Swing Arm Bolts
Old Oct 6, 2003 | 11:33 PM
Bradracer18's Avatar
Default Swing Arm Bolts
Ok guys, see if you can help or if you have the same problems. I have a 96 Sport and have problems with the swing arm bolts staying tight, does anyone else have this problem??? What can i do to fix this, or why do you figure its doing it in the first place?? Any suggestions would help. Chains are very expensive after the 4th or 5th one. thanks a lot.
Old Oct 7, 2003 | 12:22 AM
Charlie's Avatar
My first guess would be the bolt holes in the frame are egged out and the bolts are grooved. I have cut the washer out that they used at the factory and welded in a new ones before, sometimes both sides are bad enough to do both. Its a good idea to check the bushings in the swingarm while you are there.
That was one of the flaws in that rear suspension that I have seen and it does take a lot of miles to happen.
Old Oct 7, 2003 | 10:20 AM
Hey thanks charlie. Yeah my bike does have a lot of miles, but these bolts keep loosening up, not because of wear. i have welded in washers and then i just welded the bolts in. not sure if that is ok but i did it.
Old Oct 7, 2003 | 12:44 PM
Bubba297's Avatar
I did the same on my old 95 Sport. Welded the bolts enough to stay put with new locknuts. Didnt have a problem after that.Bubba
Old Oct 7, 2003 | 07:14 PM
duneaholic's Avatar
It happened to both my 400's. I got some industrial locktite and tightened it to a 150ft\lbs of torque. They haven't came loose again. Oh yeah, don't forget to clean the ends real good before you locktite and tighten.
Old Oct 8, 2003 | 09:05 PM
ftwflh's Avatar
LOC TITE RED
Joe454
Nov 20, 2020 01:19 PM
fd24
Jan 16, 2019 08:59 AM
EIF
Apr 20, 2017 07:15 PM
firsttimerider
Sep 20, 2015 09:07 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
