Warrior Rear Axle nut size?
Old Oct 7, 2003 | 11:51 AM
Warrior350CR's Avatar
Default Warrior Rear Axle nut size?
Does anybody know the size of the rear axle nut on the Warrior? I believe it is 50mm, but need verification.
Thanks
Old Oct 7, 2003 | 12:06 PM
NLWarrior01's Avatar
You must be talking about the nut right at the bearing case right? The spindle nuts are not near that big. I have the clymer manual at home .. I'll have a check this evening and let you know.
Old Oct 7, 2003 | 12:33 PM
Yes, the axle nuts right near the bearing case - there are two on the left side as you look at the cuad from the rear.
Thanks.
Old Oct 7, 2003 | 12:50 PM
KGB's Avatar
KGB
Its pipe wrench size!
Old Oct 8, 2003 | 06:38 AM
The clymer manual doesn't specify the actual size of the nuts, but I measured them and they are around 50mm .. maybe say on a range of 49-51 .. if you were looking to buy a wrench, make sure you keep in nice and clean incase it doesn't fit. I had to do that before with my B2200 hub nuts. Damn mazda dealer told me the wrong size so I ended up having to return the wrench and get the proper size.
1986Vmax540
Jul 9, 2021 09:53 PM
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
Rider252
Jul 6, 2015 03:37 PM
