raptor starting prob
Old Oct 8, 2003 | 10:53 AM
Dstang97's Avatar
Default raptor starting prob
my 01 raptor willl only star in nuetral. If it is in gear and i pull in the clutch it still wont start.
Is there a sensor or something that may be doing this?
thanks dan
Old Oct 8, 2003 | 11:15 AM
Raptor149's Avatar
If you still have your parking brake on there is a sensor there that might have come loose or is causing it to cut out. Check your clutch cable for adjustment. If it is not fully disengaging, it might not be letting the engine crank if it thinks it is still in gear, maybe.
Old Oct 8, 2003 | 12:05 PM
Starky's Avatar
Mine is the same way. When I took the parking brake off it made it so I can only start it in neutral. Think of it as a blessing though. From what I've been told, one of the possible causes of 01 trany failures was starting in gear.
Old Oct 8, 2003 | 12:13 PM
Smitty15's Avatar
So the tranny and axle problems were fixed, do we know if there are any problems with the 03' or are they finally perfect?
Thanks..
Smitty
Old Oct 8, 2003 | 01:10 PM
warrior007's Avatar
01-04 still have the same starter one-way. it will go bad eventually.
There are 2 sensors on the original clutch perch, one for the parking brake, one for the clutch sensor. If you unplugged both under the front cowl the parking brake is ok. but the other clutch sensor has 2 wires with connectors on each end. plug them into each other and it will start in any gear and nuetral
When I hillclimb and get stuck or get into some think goop its impossible to start get into neutral. its a must to start in gear
Old Oct 8, 2003 | 03:01 PM
Dstang97's Avatar
thanks a lot for the info. i did not even think about that. i did disconnect my parking break and thats why it only starts in nuetral. do u suggest just starting in nuetral or connecting the two wires so it will start in every gear? it is an 01 so what do u think?
Old Oct 10, 2003 | 11:08 AM
Raptor149's Avatar
I agree with 007, there are certain situations where you can't get the bike into neutral after a stall. You need to be able to just pull in the clutch and get going again.
AtvManiac78
Jul 11, 2015 03:20 AM
Dabears1983
Jun 23, 2015 04:59 AM
Dabears1983
Jun 16, 2015 12:17 PM
1000gade
May 27, 2015 12:37 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
