battery size
Old Oct 8, 2003 | 10:39 PM
SANDMAN430's Avatar
Default battery size
does anyone know the size of battery needed to work on the ds? the battery on the ktm 525 is a y something 4 and the ds calls for a y15, the amp hour are big different the 4 was at 4 or 5 and the 15 was at 13, wondering if that small battery would smoke the starter? well the weight difference was about 7 pounds. that is the reason for the question.
Old Oct 8, 2003 | 11:11 PM
buttfungus's Avatar
Here is the stock battery info:
Battery Family: Maintenance Free
Battery Type: YTX15L-BS
Voltage: 12
Capacity: 13
Dimensions: 6 7/8" x 3 7/16" x 5 1/8"
Weight: 8.8 lbs.
Metric Dimensions: 175mm x 87mm x 130mm
Metric Weight: 4.0 kg
Polarity:
Acid Volume: 0.75
Amps: 1.3
C.C.A.: 230
I switched to an Odyessy pc-545 because it's a dry cell and you can mount it sideways and more cranking power.
Bratman2
Aug 6, 2022 01:42 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Schneider
Jul 24, 2015 05:05 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
