How do I remove the back up override on 2002 Grizzly
Old Oct 9, 2003 | 08:52 PM
peckerhead's Avatar
Default How do I remove the back up override on 2002 Grizzly
My Grizzly cuts out when I try to back out when stuck in the mud. How do I remove the reverse override?
Old Oct 9, 2003 | 09:06 PM
hondaracer305's Avatar
Doesnt the reverse override button(if theres one on a griz) keep it from cutting out. my friend uses his override button in reverse and he can smoke the tires with it in override.
Old Oct 9, 2003 | 09:15 PM
peckerhead's Avatar
The 2002 doesn't have a reverse override switch.
Old Oct 9, 2003 | 09:20 PM
my bad, i guess its the 2003/04 model if they even have it, sorry then, i dont know how to help [img]i/expressions/face-icon-small-blush.gif[/img]
Old Oct 9, 2003 | 11:48 PM
Rackman's Avatar
Easyest way is buy a 2004 it comes with it
Old Oct 10, 2003 | 07:18 PM
shane8303's Avatar
For Grizzly 660 Rev Limiter Overrides see my photo page... I moved the write-up there and added some photos.
Old Oct 10, 2003 | 08:48 PM
peckerhead's Avatar
Thank You so much. I will try it and let you know how I made out.
Old Oct 10, 2003 | 11:48 PM
Wrecker's Avatar
Go to your dealer and get a YZ type kill switch, they work awesome for the override. That way you won't have to worry about your wife/girlfriend, or some kid punching the gas on your quad in reverse and hitting 70 before it flips and someone gets hurt, which can happen if you cut the wires.
Old Oct 11, 2003 | 09:26 AM
Kraw's Avatar
shane8303, thanks for the writeup! I may do that after I get my Mudlites!
Old Oct 12, 2003 | 01:14 AM
SilverBear's Avatar
Peckerhead~
Here's some other directions with a couple of pics on the reverse override on my website:
2002 Grizzly Reverse Override How To
I also bought an 04 LE mettalic Grizz, and an extra control pod with the built in override switch. One of these days, I'll redo my difflock override, and run it like it is on the 04's. Once done, I'll so a post on retro fitting that with the wiring diagram.
Good luck,
SilverBear
