28" Mudzilla on a Rincon?
Old Oct 9, 2003 | 09:07 PM
Duramax's Avatar
Default 28" Mudzilla on a Rincon?
Are 28" Mudzillas to large to run on the Rinny? I run into a set today that are brand new. 28" x 12 x12 (4 of them) on deep ITP C series wheels and committed to buying them without really thinking it through. It is one of those things that I feel I can not get out of. A case of shooting off the mouth before loading the brain. Thanks
Old Oct 9, 2003 | 10:53 PM
OkieFromOklahoma's Avatar
Duramax
I hope you don't plan on trying to load that in the back of your truck.Deep dish 12's on front might clear the truck fender wells.I would think those tires are heavy also.I have seen others that run 27's but don't remember 28's.I just installed the new Maxxis 8-spoke wheels with Mudlite 26-10-12's on front(+15mm offset)and 26-12-12's on the rear(-43mm offset).Boy that Rinny is wide,only 2-3 inches clearance on each side of the truck bed.Looks mean ,but I don't know how it will handle as I just put them on.
Okie
Old Oct 9, 2003 | 11:49 PM
Duramax's Avatar
Does it clear the tire wells or do you have to crawl over them or are you using the ramp Schef uses?
Old Oct 9, 2003 | 11:59 PM
I am using the ramp,but I have 10's in front with no neg.offset on the front rims.If your front with 12's are as wide as my rear with 12's you would have to climb over the wheel wells.
Nondem
Feb 22, 2020 12:20 PM
nyroc
Dec 7, 2002 11:42 PM
nyroc
Dec 30, 2001 07:05 PM
nyroc
Dec 13, 2001 10:21 AM
YZGUY
Sep 21, 2001 10:12 AM
