Can anybody help me out? Question about a atc110
Old Oct 12, 2003 | 08:08 PM
wildchild660R's Avatar
Default Can anybody help me out? Question about a atc110
Hey my dad and I just picked up a atc110 to just play around on and when we try and put in it high gears it wont go. Its stuck in low range. So we pulled off the cover and found that there was a spacer not allowing it to slide it to go to the high gears so we took that off and now it moves but when you try and go in the high range gears its like its in nuetral and just wont go anywhere. Also when your riding in low range it pops into high range sometimes and acts like you hit nuetral. I am guessing it is missing a gear because the guy said that he took something out or put something in to make it so his kids couldnt go into high range gears ...... Im stumped
Old Oct 12, 2003 | 09:28 PM
Shortcut's Avatar
Make sure that shaft you took the spacer off is not corroded,I believe that has to move freely in order to shift between hi & lo.It sounds
like it's hanging up until it gets jarred while riding.
Old Oct 12, 2003 | 10:28 PM
its ok we got it fixed but thanks for your help anyways ...
Old Apr 4, 2004 | 08:04 PM
scottiejc98's Avatar
listen if u want my advice at all, get ride of it, 110 are the worse machines made by honda, i blew it away on my 12 horsepower elan (skidoo ) , with someone on back with me, then when we got to the top of the hill, it caught his leg on fire, there nothing but trouble,
____________
300 honda fourtrack(mine and dad's)
125 honda fourtrack- blown motor (bro)
125 with a 200m atc motor, TALK ABOUT FAST (not as fast as the 200s tho) (bro)
200m atc honda - broken frame(my old atc)
200s atc honda - mine - clocked doing 98 km/h in 4th gear, then slacked off to 80 pumped the trottle again
and picked itself up on the 2 back wheels for 10 min. and then i got sick of it, (i'll tell you if i ever get the ***** to put
this beast in 5th gear as long as is an atc)
kawaski kx80 - the most retarted dirtbike ever clocked doing 105, but its an 80
o yea can't forget the 6 gears and the power bands,(god dam kawaski)
12 housepower 250 elan skidoo ,worse machine in the world, (sold)
Old Apr 5, 2004 | 12:53 PM
pungohboy's Avatar
ATC110's are pretty tough. A friend of mine has one he dogs it like crazy and it holds up good. He even rigged up a turbocharger on it. I have some videos of him jumping it. click
Old Jun 21, 2015 | 10:32 PM
Trade3's Avatar
May I ask how you got it to work? I'm having the same problem with mine. Thank you.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
