Auxiliary Brake Reservoir
Old Oct 13, 2003 | 09:58 AM
spewy's Avatar
Default Auxiliary Brake Reservoir
I lost all presure to my brakes yesterday and found brake fluid coming out around the Auxiliary Brake Reservoir. I opened it and took out the gasket on the top. It appeared to be ok and I put it back in. When I used the brake again, the first pump produced an air noise and then brake fluid came out again with each use of the brake. My question is: Can the gasket go bad even if it looks ok or have I somehow cracked the reservoir or rubber line feeding to the reservoir? Has anyone had this problem and how much did it cost to replace?
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
