220 Backfiring
Old Jan 31, 2000 | 06:03 PM
chev's Avatar
My 220 is backfiring through the exhaust i put a cobra muffler on it. i thought it was running lean so i richened the mixture but it still backfires when you rev it up and on deceleration. thanks
Old Jan 31, 2000 | 06:45 PM
Tree Farmer's Avatar
Are you sure you leaned the mixture? Which way did you turn the pilot screw?
Minor backfiring on deceleration is no problem; you might want to run a plug check to see if you need to change the main jet. With only a pipe transplant, I doubt it.
Regardless, a plug reading will tell the tale.
Tree Farmer
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
