Need some help Please!!!
Old Oct 17, 2003 | 01:43 PM
sotermantoo's Avatar
Default Need some help Please!!!
I am putting my Warrior back together after replacing the cam,valves,springs, and piston. I bought the cam from Alba and when I put my lower end on TDC no matter what I do my TDC mark on my head is off. It is off just a little and if I move my cam sproket one tooth over the sprocket mark goes to the exact same place on the other side of the head mark. I am at a lost and I have taken apart my lower end and my cam chain is on the lower sprocket perfect. So, does anybody have any experience on this?
Old Oct 17, 2003 | 02:44 PM
Crotts's Avatar
I just installed the same came and there is nothing you can do to get it to line up without degreeing your cam sprocket. They dont suggest that you cut a slot in your stock sprocket because they are weak but they are probably just trying to sell their sprocket. I called Megacycle and bought their degreeing sprocket ($65 i think) just to be safe. You can run it with the stock setting and it wont hurt anything but I'm not sure which side is the best. With a dial indecator on the stock marks I got 102.75 degrees lobe center and the correct setting is 106 degrees. To get the most out of the cam you will need to degree it in,
Old Oct 20, 2003 | 10:04 AM
Hey I wanted to tell you thanks a lot. I went to Megas site and sure enough they tell you that you have to get that sprocket with that cam, so I am going to go ahead and order it. I just don't understand why Alba did not tell me I was going to need it. Thanks again.
