rear axel grease please help
Old Oct 18, 2003 | 02:06 PM
Jayblazer's Avatar
Default rear axel grease please help
I was lubbing the rear axel zerkwaiting for it to fill with grease and the gun to pop off but it never did than i noticed that there was purple grease coming out of the sides near the gear and brake is this ok or did i blow some sort of seal
Old Oct 18, 2003 | 02:39 PM
Jayblazer's Avatar
come on someone answer i am really worried about this and i have to go to work in about a half hour
Old Oct 18, 2003 | 02:53 PM
jmrpage's Avatar
hello
this is the same thing mine does . not a problem . it will never blow the grease gun off the fitting . just grease it until it starts to push grease out and thats fine .
Old Oct 18, 2003 | 02:55 PM
scootergptx's Avatar
Supersock
Hired Gun!
the purple grease is just the type polaris uses. the gun won't pop off, (assuming it's a hand held pump type). the grease coming out is normal, that's how you know you got enough in there. but you didn't say how much came and how pressure it was under going in. too much pressure going in will blow the seal, and continuing to pump more in after it is full can damage/unseat the seal. remember to lube it after every ride. grease, gas and chain lube are my biggest expenses for the quads, but cheaper than the repairs if you ignore them. hope that helped.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 18, 2003 | 03:01 PM
Jayblazer's Avatar
thanks alot for the answer guys that really puts my mind at ease just a little grease out of both sides and it was the first time i had lubbed it since i had bought it so it held alot of grease
Old Oct 18, 2003 | 08:09 PM
Krash80's Avatar
Actually, the best way to grease something and know for sure that it's getting properly greased is to use two different color greases. As you pump in new grease, you'll first see the old grease start to push out, but then keep pumping until you see the NEW grease coming out and then you'll know that you've expelled all the old grease and the grime that it collected and the whole thing is now lubed up with fresh new grease.
-Ron-
Old Feb 4, 2006 | 01:43 AM
watzupdog's Avatar
Jayblazer.
I know this is an old post. But I did the same thing you did today and that feeling that you did something wrong just want go away. I've been searching through tons of old post trying to find answers. I hope mine is okay. Unfortunatly for me. I was doing it in my garage and it was in a dark area, so I didnt see it in time. Alot of purple grease came out by the brake. I guess you would never know if you blew a seal or not. Did yours do okay. Oh and I was using a polaris hand held pump and used the polaris 3oz grease, I'd say it had about 2oz left in the tube when I started And I finished the tube. I cant believe that greasing my ATV became such a prob for me. Did I screw something up.
bmark0610
Sep 7, 2015 09:42 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
rawbdiggity
Sep 7, 2015 12:05 PM
black_thunder
Sep 7, 2015 01:24 AM
