What cam for Wolverine...Recomendations????
Old Oct 19, 2003 | 03:18 PM
shastadog's Avatar
Default What cam for Wolverine...Recomendations????
I'm going to do a mild build-up on my Wolvy. Probably just a little more compression. Have already installed the pipe K&N and the jets. When I do then engine a little later Iwant to put in a cam. Whats a good all around cam? I trail ride mostly but have some long, fast access road sections.
Old Oct 20, 2003 | 10:35 AM
95wolv's Avatar
I'm running the Web cam 88 grind cam, it is a low to mid range cam, a good all around cam that won't hurt your bottom end like a higher lift race cam will. If you do change the cam, a little bore out and higher compression works real well with it, most aftermarket cams give up a little bottom end to let you wind higher and the higher comp piston will give the bottom end back. Just make sure you put heavy duty springs on the valves when you re cam, stockers won't hold up to any more rpm. A port job while the head is off will let it breathe a lot better, too.
Old Oct 20, 2003 | 07:18 PM
SpDdEmOn's Avatar
Yeah something like a .390 lift. Dont go with a .430 or anything like that, its too high.
Old Oct 20, 2003 | 08:02 PM
shastadog's Avatar
thanks guys
