More top-end!!
Old Oct 20, 2003 | 10:54 PM
yellowexracer's Avatar
Default More top-end!!
My friend and i both have 400ex's and we are equal weight, when we are ridding at speed down the road and we both pin it he runs away from me. I need more top end
My mods:
t-4 slip on with 2" end cap
-k&n power kit
-2 2.5" holes in air lid
-18" tires
-16 countershaft
his mods:
e-series slip on with 12 disks
-20" razr tires
-stock gearing
-shaved fenders
would adding a sparks advance key and a hotcam stage 2 give me alot more top end?
Old Oct 20, 2003 | 11:17 PM
manual's Avatar
one reason is your 18" tires... you may want to change sprocket ect... world of possibiltys
Old Oct 20, 2003 | 11:32 PM
CrAcKhEaD's Avatar
yup i would have to say the tires too and the fenders also make a difference.
Old Oct 21, 2003 | 10:35 AM
In the spring i will be buying 20" tires and shaving my extra red plastic. Is there any 20" tires you guys suggest?
Old Oct 22, 2003 | 12:44 PM
Also will the hotcam help my topend alot?
Old Oct 22, 2003 | 12:56 PM
extremerider2811's Avatar
no just get a new sproket like, a stock one is 16 or 17 teeth get a 20 teeth, or get 20" tires
hope that helps
Old Oct 24, 2003 | 05:58 PM
cals400ex's Avatar
i would not get a stage2 without a higher compression piston. your jetting will also affect your speed. you may need to go with a 36 rear sprocket along with the 16 countershaft to get more top speed. the cam will mainly give power at different rpm ranges than the stock cam. it may not affect top speed too much though. also, i would bet you need to tighten the throttle cable. put it so that there is about 1/4 inch of play in the throttle lever. it if has a lot of play, your carb will not be fully opening up. this will make a huge difference if it is not adjusted correctly.
Old Oct 25, 2003 | 01:30 AM
Yea i'm thinkin i'll wait and c if santa brings me a shiny high compression piston and cam cuz with just the cam i'd be giving up alot of bottom end.
Old Oct 25, 2003 | 01:33 AM
thunderalley400ex's Avatar
LMAO!!! [img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 25, 2003 | 07:23 PM
Slacker1bob's Avatar
A stock 400ex sprocket is 14 or 15, definately not 16 or 17. A 20 tooth front sprocket wont even fit, more so, it will take a mile to get up to speed
