Throttle cable problems on the 03 Grizzly
When I turn my bars all the way to the left, the throttle is opening slightly. I have checked the adjustment on both ends of the cable, and it is turned to max length. It seems as if it were binding, but I can't find where. It just seems the cable is to short. Have any of you all experianced this? If so is there any fixes, other than the new throttle cable? I've had this bike about a year, and it has done it since the day I brought it home. Any advice is appreciated.
Good Morning, i had this problem on a lot of my suzuki motorcycles, first remove the side panels so you can see the routing of the cable, remove the cable from the easiest end(carb or throttle) remove all cable ties and reroute it so it does not bind anywhere, then adjust freeplay,, untill it works properly
then add ties one at a time, checking after each one. should work
robert
03 grizz
robert
03 grizz
toonces
Oct 16, 2019 12:11 PM
ranvette
Jul 4, 2015 06:13 PM
