Bigger Rear Sprocket
Old Oct 21, 2003 | 10:23 PM
CraneMan's Avatar
Default Bigger Rear Sprocket
Any of you folks running 42 or 43 tooth rear sprockets had/having clearance problems, such as rubbing the chain guide? My new 43 tooth came today - waiting for the new front to arrive so I can change both at the same time.
Old Oct 21, 2003 | 10:33 PM
HillbillyDS's Avatar
Same gearing could be achieved via a 15 tooth CS sproket, much cheaper & no clearance issues!
Old Oct 22, 2003 | 12:17 AM
MRDS650's Avatar
Canadian and Proud of it !!!
I am in the process of installing a 43 tooth rear spocket. I had a PRM swing arm skid plate. The new sprocket would not have fit with the old skid. I am having a custom designed skid plate made for me now.
That what you mean by rubbing the chain guide right ???
Old Oct 22, 2003 | 12:38 AM
SANDMAN430's Avatar
i have the 43 rear and with the stock chain guard it rubbed but with a little riding it worked out fine.
Old Oct 22, 2003 | 06:03 PM
bigslim78's Avatar
i have the 42 rear and 15 front and it works great!!!
Old Oct 22, 2003 | 07:50 PM
CraneMan's Avatar
Thanks guys. I'm waiting for the new front sprockets to get here - ordered both 14 & 15 tooth, just haven't decided which to try first. Around here, 'I' would never use the top end a stock geared DS has - so I'm gearing down to see how many shifts I can make in 300' or less distance [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 12, 2007 | 08:21 PM
AZPredator's Avatar
I have been searching online at various sprocket companies but can't find where to buy a 42t rear for my DS.
Where are you guys getting them?
I already run a 15 tooth front with 22's..........Just want a little more low end for duning.
Thanks,
Old Aug 12, 2007 | 08:24 PM
ERBEDS650's Avatar
try this , have fun and play
http://home.earthlink.net/~gellett/ds650.htm
Old Aug 12, 2007 | 08:31 PM
MRDS650's Avatar
Try:
http://www.sprocketspecialists.com or If you really have to and have money to burn you can try "Sidewinder" as well
Old Aug 12, 2007 | 09:24 PM
AZPredator's Avatar
Thanks,
I don't have money to burn, so I just found and ordered a 42t rear from Albaaction.
I'm a big fat guy and need to get this 820lbs of quad and man moving a little quicker in the sand and trails. [img]i/expressions/face-icon-small-blush.gif[/img]
