Bigger Rear Sprocket
Old Aug 12, 2007 | 10:27 PM
MRDS650's Avatar
Canadian and Proud of it !!!
Default Bigger Rear Sprocket
15/42 is a great gearing combo, I have run it for a few years. I am just now changing to a 16/41 because I now have the power to pull the taller gearing and want to put a new rear skid without having to modify it to fit.
Old Aug 14, 2007 | 01:53 AM
AZPredator's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: MRDS650
15/42 is a great gearing combo, I have run it for a few years. I am just now changing to a 16/41 because I now have the power to pull the taller gearing and want to put a new rear skid without having to modify it to fit.</end quote></div>
I have heard that some mod the rear skid plate and some don't and let the chain eat the plastic. I guess i'll find out soon huh?
I haven't looked at the rear skid, can you put some washers in there to give it a little space???
Also, I have read that you have to take off a wheel hub to get the sprocket on? How do you take off a hub. I'm sure I can figure it out, but never even looked at how to get it off or put it back on................Just want it to go smoothly.
Thanks for your help.
Old Aug 14, 2007 | 02:17 AM
MRDS650's Avatar
I had to cut off the plastic part just so the chain would clear. I also had to cut the end of the sid plate(closest to the rear) bend down the kick ups and then get them re-welded.
You cant space out the skid plate either beacuase the bolts all come in from the side.
The new spocket should fit over the hub just work it around until it goes over.
Old Aug 14, 2007 | 02:26 AM
AZPredator's Avatar
The new spocket should fit over the hub just work it around until it goes over.</end quote></div>
Damn, looks like alot of work. Anyone out there make a nice skid that has the extra space??? Might be a good time to get a good "rock hopper" protector.................Thanks,
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
Dammar
Aug 26, 2015 07:12 PM
rcappie4
Jul 10, 2015 04:54 PM
