250R Carb
Old Oct 23, 2003 | 02:41 AM
Tin's Avatar
Tin
Default 250R Carb
1986 TRX 250R. I just put a 38mm air stryker on a Boysean rad valve manifold.
The air boot from the large side of the carb to the air box does
not even come close to fitting, angle, or alignment wise.
Any one else have a problem like this? What's the deal?
If I loosen and tweak the manifold rubber mount I can get the rear air boot to line up,
but then I don't get a good postive at the reed cage or the small side of the carb.
Old Oct 23, 2003 | 04:05 AM
elsancho's Avatar
Default 250R Carb
use a CR250 airintake boot. it has a different kick to it and is made to be used with a 38mm carb...get them from your parts subbly or from ESR. but befor you spend teh money try using a heat gun to soften the rubber
Old Oct 23, 2003 | 02:00 PM
td250r's Avatar
Default 250R Carb
Sorry I cant help, but I am very interested in how it turns out. I have heard a few people having that problem with it not fitting.
I was also considering using the ESR air filter and removing the the whole air box. Anybody have any experience with this? Im using a bored stock cylinder with some porting, would this be to much? I ride probably 75% dunes, and dirt the rest, no water.
Eventually, when the funds are available, I would like to bump up to a 330 or 350 pv, would a 38/39 carb still work for this setup?
Thanks in advance.
86 trx250r
97 warrior
Old Oct 23, 2003 | 03:00 PM
elsancho's Avatar
Default 250R Carb
the 38/39/40 mm carb works great with teh 350 PV. i actually have mine going up for auction on ebay tonight
Old Oct 24, 2003 | 03:29 PM
machwon's Avatar
Default 250R Carb
Heat the boot up in hot water. They all will bend together nicely sooner or later.
Old Nov 8, 2003 | 05:19 AM
bertfull's Avatar
Default 250R Carb
I have a 38A/S w/ Rad Valve & stock Air-filter boot on my Quad. Soak the boots in hot water for about ten minutes. This makes the rubber a lot more pliable & you'll be able to stretch it onto the carb. I've been running mine for Two years without failure.
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Dustinyoungs
Jul 24, 2015 07:18 AM
Aitch
Jul 21, 2015 09:40 PM
CRamshaw777
Jul 18, 2015 05:46 PM
