300ex hates water
Old Jun 12, 2000 | 07:10 PM
crashnburn's Avatar
I know this question has been asked but I haven't found an answer yet. I have dielectric greased everything and it still spits and sputters when I hit water. Has anybody found something to prevent my wheeler from stalling when hitting water.
Old Jun 13, 2000 | 12:49 AM
dan300ex's Avatar
sounds like you have a cut or pin size hole in your spark plug cap . check it in the dark of night for small sparks against the side of the head by the plug cap .
Old Jun 13, 2000 | 05:33 PM
crashnburn's Avatar
I'll try that but I don't think it will work. I've sprayed that area with a hose when its running and I can't get it to act like it does when I'm riding.
Old Jun 13, 2000 | 05:46 PM
cstark's Avatar
You are getting water in your CDI box connections.
The CDI box is mounted on the frame under the right front fender(throttle side). It's a small rectangular box(4"x3"x1").
Remove the connector from the CDI box and clean both ends. Apply dielectric grease to the connections and re-install. I also place heat-shrink over the connection and constrict it. Anything that can stop water from splashing up on it will help.
Hope this helps.
Chris 00' TC Racing 300EX
Customer Service #1
May 15, 2020 08:46 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
