4 valves better than 5
Old Oct 24, 2003 | 11:26 PM
ridinsmooth's Avatar
Default 4 valves better than 5
i mean the 450r has 4 and the yzf 450 has 5
Old Oct 25, 2003 | 12:22 AM
Yellow650Rincon's Avatar
Ummm...ok?
Old Oct 25, 2003 | 05:25 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Can't remember what the principle is, but two small valves are more efficient than one large valve. That is why the modern engines have 4-valve heads (two intake and two exhaust). Yamaha tried to do one better, and added an extra intake valve. If two is good, three is better, I guess????????
Old Oct 25, 2003 | 09:25 AM
MOJAVE02's Avatar
there is no advantage and there is no disadvantage. see every engine needs to breath differently. some engines will produce more horsepower with 5 valves where others can produce more with 4 valves.
Old Oct 25, 2003 | 11:28 PM
amsoil123's Avatar
Originally posted by: Ridley
it's all about velocity. 5 valves offers the same volume as 4 valves, but the charge comes in at a higher velocity, increasing efficiency. Unless your running boost, 5 valves will always be better. Hence the yz450f making 2 more hp than the CRF450(dirtbikes) [img]i/expressions/face-icon-small-wink.gif[/img]
Um.....I read that the CRF has 11 more hp than the YZF!!!!!!!But I can't go against Ridley, he's all about the facts....plus I'm one of those YFZ owners that dosn't want to have his a$$ handed to him at the track!!I'm not going to lie to ya!!!!!!!!!!!!![img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 26, 2003 | 01:45 AM
Sandgod's Avatar
Though it's not a quad the GSXR1000 kicks the crap out of an R1. I think how many valves is only part of the equation.
Old Oct 27, 2003 | 12:05 PM
NLWarrior01's Avatar
Ok, here's the link. And next time someone says the CRF is better, make sure they can see how the yfz makes more power almost EVERYWHERE. I also like this graph, because it shows how the moto 440's engines actually are compared to either the yamaha or honda. Enjoy [img]i/expressions/face-icon-small-wink.gif[/img]
YZ450 vs CRF 450 Dyno
Even guestimating the yfz and trx horsepower at this time is pointless. However, when both are brought up to race specs, you could expect them to closely mirror the above dyno's, especially the yamaha since it's the same motor. Who knows what honda's will make, but I would imagine it would be less than the CRF in peak hp, but maybe a little more down low with the longer stroke. Also, from what I've seen, both motors respond about the same to pipes, and the yammy retains the 2 hp advantage(actually, the yammy gains a little more from a pipe). I wouldn't worry about getting smoked Amsoil. It will come down to the rider no matter which one you choose. 2 hp isn't a whole lot either way.
From the dyno it's actually only 1.4hp anyway .. and it seems to me, also from the dyno that the honda would get the holeshot on the yammi .. it makes more power earlier than the yammi. Love to have a go on either one of the two tho .. they both kick the cr@p out of the Warrior .. LOL
Old Oct 27, 2003 | 12:31 PM
extremerider2811's Avatar
does the 450r have a DOHC or a SOHC?
later
Old Oct 27, 2003 | 12:56 PM
SupraMan400's Avatar
The 450R is equipped with the unicam system. This single cam supposedly performs similarly to the DOHC design without the added weight of an extra cam.
Old Oct 27, 2003 | 09:15 PM
I was talking about the peak generated HP .. yz = 49, crf = 47.6 .. diff = 1.4
The honda makes it at a fairly lower rpm too (at least in this scale) .. what do the torque charts look like? Where does each produce it's peak torque ?
I'm not bashin the yammi, nor propping the honda .. both are wicked machines as stated earlier .. and I dont' own either as you can see by my sig .. just going on what I'm reading from the charts .. l8r's all!
