11.1 JE piston and Hotcam
guys, I can't make up my mind, so I need some help here.
which Hotcam should I go for using 11.1 JE stock bore piston? Stage I or stage II ? I am not doing any porting now.
thanks
Adel
thanks
Adel
well I mostly do sandy hill climbing. big a$$ hills too, I would start climbing in 3rd gear (12/40 gearing) and 3/4 up the hill I would down-shift to 2nd till the end, so I guess most of the time I would at WOT.
I am just worried about running the stage 2 cam with only 11.1 compression piston, I know this cam works best with 12.1 pistons. let's just say most of my riding will not allow me to go below 3/4 to WOT.
thanks
thanks
I have a 102mm 11:1 Je piston..........and a stage 2 cam.......and this thing as TONS of grunt from thebottom to the top...........it is the strongest quad that I have ridden.......I know there are plenty out there that would gladly had my a$$ to me........but it is STRONG
I had a stock bore 11:1 and a stage one cam previously.........and my current set up is LOTS stronger than before..........
[i]Originally posted by: [b]BigScary
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
