Jetting a 2004 700 after K&N filter install ???
Old Oct 26, 2003 | 10:00 AM
Mark82ndABN's Avatar
Default Jetting a 2004 700 after K&N filter install ???
I'm putting a K&N air filter in my 2004 Sportsman 700 and I need to know if and how I need to jet the carb. I'm new to all of this so any input would help. I'm not in a high elevation and for now I will keep the stock exhaust. Thanks, Mark.
Old Oct 26, 2003 | 12:26 PM
RookWV's Avatar
You're probably going to be OK with the stock jetting as it's probably a bit rich to begin with....just be sure to check your plug.
Here's some links that may help:
http://www.motocross.com/motoprof/mo...lug2/plug2.htm
http://www.gnttype.org/techarea/engine/plugs.html
http://www.strappe.com/plugs.html
http://www.nightrider.com/biketech/spkplghnbook.htm
http://www.hioutput.com/tech/plug.html
http://www.victorylibrary.com/mopar/plug-read.htm
http://www.cyclewerksracing.com/reading_spark_plugs.htm
http://www.splitfire.com/plugtips.htm
http://www.ngksparkplugs.com/techinf...31000&country=
http://performanceunlimited.com/illu...parkplugs.html
JETTING
http://www.speedandsport.com/jet.html
http://www.dynojet.com/motorjet.shtml
Old Oct 26, 2003 | 01:50 PM
Traildog's Avatar
I installed a K&N on my 98 Sportsman 500 and my 01 Sportsman 500 HO and in both cases no rejetting was required.
Old Oct 26, 2003 | 02:03 PM
Thanks a million for all the links guys. I appreciate it, Mark.
Old Oct 26, 2003 | 02:06 PM
fishslab's Avatar
I'm with every body else. They tend to be a little rich anyways. You should be ok.
Old Oct 26, 2003 | 02:24 PM
markie's Avatar
my dealer installed a high alt kite and installed counter weights on the tran for $90 ,makes a big differance.
Old Oct 26, 2003 | 10:54 PM
markie's Avatar
What do you think of a bigger carb on the 700.
GregM
Jul 29, 2015 09:41 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Aitch
Jul 21, 2015 09:40 PM
cSchwartz
Jul 9, 2015 02:43 PM
