YFZ450 Killswitch Installation
Old Oct 27, 2003 | 02:33 PM
BritBoy's Avatar
Default YFZ450 Killswitch Installation
Hi guys, I have a YFZ450 and want to know the correct method to wire my pro design killswitch. I need detailed instructions as to what to connect, not just cut the white wire and attach etc. Thanks
Old Oct 27, 2003 | 02:41 PM
selector's Avatar
I'd suggest getting the shop manual that includes a complete wiring diagram.
Old Oct 27, 2003 | 02:47 PM
BritBoy's Avatar
i have the shop manual and still cant work out what to do! any others please??
Old Oct 27, 2003 | 05:14 PM
pudljumpr's Avatar
Ok, first start at your flywheel cover (left side of machine right next to where you check oil in the engine, not the tank). There should be wires coming out of your flywheel cover for the stator. Follow them up under the radiator, and up near the main wiring harness (still on left side of machine). As you follow this wire, you will see it turns into a black connector and you can now see 2 colored wires. You want to splice into the all white wire. (some wires are white with a colored stripe, don't use those) If you want to double check that you are on the right wire, disconnect this black connector and you should have a neutral light on with the key on, but the machine won't start. Splice into the all white wire with the positive wire of the tether, it will be the longer of the 2 wires. Use shrink wrap over the connection to water-proof it. Then take the shorter wire from the tether and crimp a spade end on it and ground it somewhere to the frame. I used the bolts that hold on the voltage regulator (small silver box with air fins near front shock mounts. Then all should be set. PM me if you're still confused!
Old Oct 27, 2003 | 05:36 PM
BritBoy's Avatar
thanks for the info....another question- what do you mean exactly by splice into the white wire? do i cut the white and put the positive wire inbetween before reconnecting all three ends? how do i do it? thanks
Old Oct 27, 2003 | 07:26 PM
pudljumpr's Avatar
The connector you want is called a scotch lock. I can't remember what size you need. But basically you can take this connector and slip it over the white wire, insert your + tether wire, and there is a metal piece you pinch down with your pliers and it automatically taps into both wires. Then you just bend a plastic peice that clips over top of the metal you just pinched and it's done. Put some shrink wrap or black tape on to water proof it a little.
Old Oct 27, 2003 | 08:58 PM
raptorblasterracer's Avatar
huh tap into one of the wires coming out od cdi box...forgot which one i asked on the formes and some1 told me
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Sep 23, 2015 06:23 AM
toonces
Sep 5, 2015 01:14 PM
