New to Honda ATC, Need advice!
Old Oct 29, 2003 | 11:57 AM
ThrashAndCrash's Avatar
Default New to Honda ATC, Need advice!
I just bought my 84 Honda ATC 200X. What weight of oil should I use? As far as I know this is a low hour orignal engine. I get smoke on first fireup (valve guides?) but after that it's pretty clean!
Has anyone heard of moding a mono-shock? I have heard it is possible to install a schrader valve in the oil side of the shock so you can recharge the oil instead of spending the $700+ for a new one? Thanks
Old Oct 29, 2003 | 12:29 PM
HA2's Avatar
HA2
we ran 30 weight in our 200x's, all of them still are running today.
Old Oct 29, 2003 | 12:34 PM
Did they kick over OK with the straight 30? Temps are dropping around 40deg. now and this thing is a bear to kick anyway(no compression release!)
Old Oct 29, 2003 | 02:03 PM
HA2's Avatar
HA2
we ran it stricly in our deserts so my example is pretty irrelivant i suppose. i could probably start it with my hand.
Old Oct 29, 2003 | 05:31 PM
truckpaul's Avatar
10w-40 will run just perfect in your machine. Summer or Winter time here in Ohio. Not sure about the shock, sorry.
Old Oct 29, 2003 | 09:34 PM
fast440's Avatar
I just bought an 84 200x also and the shop manual says to run 10w 40, but I suppose it may differ depending on temp
Old Oct 30, 2003 | 09:52 PM
cpalm1's Avatar
i run 10w-40 year round in my ATCs. i just use regular oil, but depending on how you ride you might want to use synthetic.
Old Oct 31, 2003 | 02:39 AM
Bulldog250R's Avatar
Thrash- I have run 10 40 with lucas hd oil stabilizer(quiets gearboxes, helps run cooler, etc). Im in S.E. Iowa, it gets pretty chilly, never had a problem kicking a bike with this setup. Cant help you with the mono shock mod, I would be interested in doing that too if anybody has any info on it!
Old Nov 2, 2003 | 11:32 PM
I took the 200X out this weekend and used the 10W40.b Thanks to all !!!!! Have a question though.......The 200X normally have a LOUD timing chain? Runs good but you can hear the timing chain over the exaust! I hear the tentioners go bad?
Old Nov 3, 2003 | 12:46 PM
Michiganredneck's Avatar
10W - 40 is fine. Just make sure you check the oil every time you ride, because there is only a bit over a quart in the crankcase and if you run low you will starve it for oil and sieze the thing up.
Polaris5
Aug 29, 2015 09:11 PM
heath legg
Jul 24, 2015 01:01 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Scottma518
Jul 10, 2015 12:42 AM
