need your help guys (a-arms are installed but )
Old Oct 30, 2003 | 11:42 AM
FsT4WrD's Avatar
Default need your help guys (a-arms are installed but )
Well the site will not let me post the link to where the pics are cause there are on another forum , but the problem is the lft upper heim joint is about 6 to 7 threads out further then the right upper heim , if I make them even , the left side camber will be way to positive . The are set perfect right now but I am concerned if its even rideable . Getto measurement example is : lft side = 2 fingures between lock nut and joint , RT side = one fingure between lock nut and joint .
Thanks , if you want the link to the pics pm me.
Old Oct 30, 2003 | 01:38 PM
Starky's Avatar
Mine is the same way. One side is out a half inch or so farther to make them even. It may be that there is a slight tweek in the steering stem. Just adjust them so the camber is correct on both wheels. That's why they're adjustable.
Old Oct 30, 2003 | 02:01 PM
KGB's Avatar
KGB
FsT$WrD,
Mine is like that too. Mine are JD a arms, but I could not adjust it out, so I just ride it, it works fine.
How did you get the ball joint out?
Old Nov 4, 2003 | 08:16 PM
FsT4WrD's Avatar
OMG what a difference , I talked with ASR and gave them measurements and everything was fine . I still can not believe how well this thing handles now
Old Nov 4, 2003 | 09:17 PM
Starky's Avatar
Ya, it's awsom compared to stock. Feels like you're on rails. What degree of camber did you go with. I only went 2 degrees.
toonces
Oct 16, 2019 12:11 PM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
traumajunkie
Jul 5, 2015 03:03 PM
Mphillips
Jul 2, 2015 07:20 PM
