works shocks
Old Oct 30, 2003 | 11:24 PM
Aminal's Avatar
Default works shocks
wow, who would have thought works makes shocks for my sport, go to www.worksperformance.com they have struts and piggyback rears and others, great stuff i wander if they're any good
Old Oct 30, 2003 | 11:41 PM
pudljumpr's Avatar
They make a huge difference!! I had them on my previous scrammy, on the front anyway. $240 for the front pair. They revalve them for your weight and riding style. They have progressive dampning, so they feel soft at low speed, but the faster you ride, the better they respond and fight against bottoming. I had no problem clearing 40ft. tables with the scrammy, while at the same time blazing through the woods it would soak up roots and bumps wonderfully, great mod!! The rear shock most likely is equally great, with just a rezzi, or rebound and compression adjustments!
Old Oct 31, 2003 | 03:29 PM
dodgepower's Avatar
Speaking of that guys what is the best way to set the rear shock (factory) on a scrammy. I am about 185 lbs should it be more towards the top or bottom. Also how do you know if need to replace or refill the reservoir?
Old Oct 31, 2003 | 04:27 PM
fishslab's Avatar
Unscrew the adjuster all the way. Hit some jumps and find out where it bottoms out. You want to tighten it up just to the point you don't bottom out on some serious jumps. If the reservior hasn't leaked then it should be fine.
Old Oct 31, 2003 | 04:53 PM
dodgepower's Avatar
Roger that appreciate it brother.
hugemoth
Jul 20, 2020 03:28 AM
1966F100
Jul 12, 2015 03:08 AM
cSchwartz
Jul 9, 2015 02:40 PM
Jkfx400P
Jul 6, 2015 10:04 AM
bikedad3
Jul 2, 2015 02:15 AM
