Banshee pipe question
Old Oct 31, 2003 | 12:16 AM
ThreeWRacer's Avatar
Default Banshee pipe question
I know this is a atv forum but this still involves an atv. I have a 1975 Merc snowmobile. Its a 340. I was wondering if i could use pipes and silencers from a banshee on it. I think the banshee is a 350. I know ill have a hard time finding aftermarket pipes for a 75 merc. Now this sled is a bit far from stock but still has a stock moter. Ive mostly rebuilt the suspension. Withabout 12 inches in the back and 9 in the front. Ill have pics up soon. If you want pics now send a private message and ill email ya some.
Old Oct 31, 2003 | 10:19 AM
DeuceRooster's Avatar
Don't know about the pipes but I'm sure the silencers would be pretty easy to use.
Old Nov 3, 2003 | 10:04 PM
well my goal was to make it loud
Old Nov 4, 2003 | 12:02 AM
WyoDuner's Avatar
Brilliant. [img]i/expressions/face-icon-small-sad.gif[/img] Just what the sports need - more noise.
[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Nov 5, 2003 | 04:52 PM
Well Im only going to ride on my property so sound isnt a big concern. It wont be on the trail. Just privatly riddin. This is strickly a back yard basher.
Old Nov 6, 2003 | 07:03 PM
c-mon people i need some help.Is a banshee engine differ in any way with a snowmobile engine. Is the banshee liquid or air cooled
Old Nov 6, 2003 | 08:51 PM
machwon's Avatar
Banshee's are liquid cooled. The common aftermarket pipe usually rev out to 9500 with peak power more in the 7500-8500 rpm range. Drag style pipe get into the 10500 to 12000 rpm. Your biggest issue will be how comparible is the bore and stroke of the 340 and whether it was really intended to run that kind of rpm. The pipe won't be much help if your motor won't rev that far or is turning 5000fps piston speed. The other issue is what is your clutching tuned to rev out at?
Old Nov 7, 2003 | 06:29 PM
well i dout a 1975 motar will ever turn 12000 rpm. stock it probably turns 6500 max. The clutch comes in about 3500 to 4000 rpm. I was kinda lookin for more low end torque but now im getting picky. [img]i/expressions/face-icon-small-smile.gif[/img] I wonder if a4 stroke pipe would work. Idought it though.
Old Nov 7, 2003 | 06:30 PM
Do they make a banshee pipe that offers more low end?
Old Nov 7, 2003 | 09:39 PM
machwon's Avatar
There is a 2 into 1 banshee pipe which was for more low end. Is this sled "snow twister" or just a mercury trail sled? If you happen to know the bore, stroke and rod length I could probably give you an idea of what kinda rpms its capable of as long as the ignition revs out and its clutched right. I've seen some good running trail 340's turning 8500 in the 1973 ski-doo free air's. Have you checked with any vintage sled clubs?
