300 Jetting
Old Nov 1, 2003 | 01:16 AM
Smoke's Avatar
Default 300 Jetting
2002 300 4x4, looking for a few more ponies!!! How would I jet this for @ 1200' elevation (southern ohio). I havent touched this carb before, and dotn have a whoel lot of experience?
Here is waht I do Know
1) bad cold starts
2) Backfiring going down hills (some say this is normal?)
3) spark plugs seem to be a bit black
How do I fix these problems in terms of adjusting my carb? What and how do I adjust, and do I need a "jet kit"? What size main for my elevation again @1200' (southern ohio).
Just looking to tune her up and squeeze a few more ponies out of her, I know she can do it!! Thanks in advance
Old Nov 3, 2003 | 11:00 AM
Cancat's Avatar
Default 300 Jetting
Hey Smoke
My 250 is a little sluggish to start, and it does back fire if you are hard on the throttle and then let right of...and going down hills, and my plug is a little dark. I found that when I got it it did none of these things, but it was running to lean, so I richened it up. So now it has these little problems, but the power and top end improved, so you may find that you are setup pretty good, unless you want optimum fuel mileage.
All I did was play with the setting a bit, if all else fails get a manual and set it to factory, but you may be dissapointed with the power loss.
Hope this helps.
CanCat
Old Nov 5, 2003 | 07:43 PM
Arctic388's Avatar
Default 300 Jetting
i always had the same problems and nobody on here ever had any recommendations
i left mine stock and sold it finally and now savin to get me either a 500 or 650
the more i vist the dealer the more i think the 500 is plenty but have been waiting for them to get a 650
some time it would pop going down hill and sometime not.
i also had problem when climbing steep hills for it to stall.
didnt know how to fix that either.
but when i did route those vent hoses farther up it helped some with the stalling
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
