Bearing bad already.
Old Nov 1, 2003 | 11:13 AM
Halfliter's Avatar
Default Bearing bad already.
I did a search on here about the bottom steering stem bearing. A few guys had to replace them but it don't seem like huge a problem area. I have an '04 X with about 15 hrs on it and the bearing is loose already. I don't think thats right. Do you guys think the dealer should warranty it or is it not worth the hassle? The rod ends ar a little loose also but I think that is probably acceptable normal wear. Other than that I love this thing. Great trail machine. Super, super comfy!
Old Nov 1, 2003 | 11:26 AM
SANDMAN430's Avatar
wouldn't hurt to take it back and see what they say. they might say yes.
Old Nov 1, 2003 | 01:22 PM
jiminok's Avatar
Have you tried just tightening things up a bit? The only wear n tear you should see after 15 hrs would be tires...maybe. Unless you have 100% confidence in your dealership and you have money to burn I would seriously start investing in your tool selection and a manual. Get your torque ratchets and sockets and get to know your quad...your safety and your quad parts life expectancy will be greatly enhanced.
PS--get some loctite also...should just be two nuts and bolts on that bearing keeper if I remember right...mine became loose shortly after I bought it but haven't had any problems since I tightened it up.
Old Nov 1, 2003 | 11:16 PM
bigben's Avatar
Those two little bolts came loose on mine once. That bearing should last a long time- relatively light loads and few rotations.
Old Nov 1, 2003 | 11:21 PM
BajaIowa's Avatar
Diddo here. I oil the bearing regularly, but the two small bolts came loose a long time ago. After tightening, everything has stayed tight.
Justin
Old Nov 2, 2003 | 12:15 PM
Halfliter's Avatar
Thanks men. It was just the two little bolts. I wouldn't think that the bearing could go bad. Like you said, it don't turn much with any load. By the way, I ordered a manual when I bought the machine. I just haven't picked it up yet. I've seen the ones on e-bay but I figured I will be better off with the one for my exact machine. Thanks again.
wendal
Aug 3, 2024 10:03 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Elkaholic
Sep 6, 2015 02:44 PM
