alky on stock bike?
Old Nov 4, 2003 | 06:47 PM
crazypainter's Avatar
Default alky on stock bike?
I'm new to 4-stroke performance so please bear with my ignorance. Can you run alky on a stock bike with a stock carb. I realize the carb would have to be modded. what are the pros and cons of running this way?
Old Nov 4, 2003 | 06:59 PM
XxDumontRaptorxX's Avatar
Alky wont do any good without bumping the engine compression higher. The whole thing about alky is it has a really high octane level (more than 140.. not sure exactly) So You can Raise the compression really high, like 14:1. Gas can't safely run this high because of preignition. It can be done, but stock... You will gain maybe 1-2 hp and waste about 2x more gas. if you change piston, intake and exhaust, it would be a huge change. IMO not worth it.
Old Nov 4, 2003 | 07:04 PM
thanks for the reply. I had no idea. I guess Iwont be trying that.
Old Nov 4, 2003 | 07:09 PM
SP700RACER's Avatar
It's worth about 2 tenth's in the 1/8 mile on a stock machine. The bsr carb can be modified real easy. drill pilot jet out to .036. drill needle seat and tube out to .125 and main jet around .116 and raise float level as high as you can without running out overflow. may need to open up fuel system to supply enough methanol. The bsr carb has a small fuel bowl and on long pulls tends to run dry without mods to the fuel system. I have some jets drilled and set up for the bsr carb, IM me and i will be glad to send you a complete alky setup. (free)
Old Nov 4, 2003 | 08:33 PM
QUADMAN650's Avatar
YOU CAN RUN ALKY ON A STOCK BIKE A ND STOCK MOTOR ALL YOU HAVE TO DO IS CHANGE TO THE TM42 OR TM45MM CARB TO JUST TRY OUT ALKY YOU CAN REMOVE THE PILOT AND THE MAIN AND IT WILL RUN AND RUN PRETTY GOOD A PIPED AND JETTED DS 37HP MY ALKY DS 42HP ONLY DIFFERENCE ALKY
Firefighter400
Oct 8, 2022 06:38 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Cantbuytime
Aug 17, 2015 06:33 PM
MONKY LONDON
Aug 11, 2015 08:39 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
