raptor clutch
Old Nov 4, 2003 | 11:05 PM
Blaster2fast's Avatar
Default raptor clutch
having problems withthe cluth... not sure what it is... its all tight and everything but doesnt work.. put it in gear and you can BARLEY move the thing... its hard... anyone got any ideaS?
Old Nov 4, 2003 | 11:06 PM
Raptor58's Avatar
if it's hard to pull the handle the cable may be freezing up.
Old Nov 4, 2003 | 11:18 PM
na it sbeen in a garage for quite a while.. a heated garage mind you
Old Nov 5, 2003 | 12:23 AM
Raptor58's Avatar
Sorry i didn't really mean freezing like cold but like not moving back and forth like it should. If you take it loose at the case and at lever you should be able to move it with your fingers it doesn't take much mudd in there to make things stiff.
Old Nov 5, 2003 | 02:11 AM
when you pull the lever it moves the little cluth thingy... it was working fine and then we took it into the dealer to get an inspection and when we got it back it didnt work...l pissen me off!!!
STLyamwar
Jul 25, 2020 04:44 AM
black_thunder
Sep 6, 2015 04:41 PM
cdstang
Aug 31, 2015 07:52 AM
Aug 25, 2015 11:16 PM
Aug 21, 2015 01:23 PM
