Inflating ATV tires using CO2 cartridges ??
Old Nov 4, 2003 | 11:28 PM
FISHER1648's Avatar
Default Inflating ATV tires using CO2 cartridges ??
A couple weekends ago I knocked one of my rear tires off the bead on the trail. Luckily, I was able to get it re-seated using a hand pump, some engine oil, and a tiedown wrapped around the circumference of the tire. It took quite a while and LOTS of pumping.
I was wondering if anybody has used the little CO2 tire inflators ? Seems these would make the job easier. How many cylinders does it take to get a std rear tire (22") to say 30-40 PSI ? I know it took about 20 min of grunt work in the dez with a standard compact bike pump.
I've got a 100 mile dez race coming up and want to be able to get the job done quicker if possible if it happens again.
Thanks, Eric
Old Nov 4, 2003 | 11:38 PM
warrior007's Avatar
I have used them, may make it a little easier to set a bead but it will take alot of them to pop it on. I would say 10 or so. 1 would barely get me up to 4 psi.
Old Nov 4, 2003 | 11:55 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I did a post on this very subject a while back.
http://forums.atvconnection.com/mess...ighlight_key=y
Old Nov 5, 2003 | 12:26 AM
FISHER1648's Avatar
10-4 ! Thanks for the info guys !
I think using the pump to get the majority of pressure and a couple CO2s to hit it quicker at the end to seat the bead might be the way to go.
Old Nov 5, 2003 | 05:12 AM
Red Rider
Or, the other way around??? Hit it hard at first to seat the bead, then the pump to finish it off???
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
