Hot cams
Old Nov 5, 2003 | 11:44 PM
Choky's Avatar
Default Hot cams
What are hot cams?What would they do to stock motor? And a pipe,jet and filter motor? Would it use more gasoline?
Old Nov 6, 2003 | 12:43 AM
14mins's Avatar
Default Hot cams
Hot cams are a alternative to web and mega-cycle cams. With hotcams you keep your stock cam. You do not have to use your factory cam as a core. They (hotcams) are cheaper than the other cams out there. They are better in my opinion. The stage 1 is a drop in cam. It will put you in front of the piped and jetted crowd. About 130 dollars from craycraft racing. Call Bob at 817 441 5893 and he will answer your questions and sell you what you need for reasonable $$
Old Nov 6, 2003 | 01:02 AM
LOWBOWTIE's Avatar
Default Hot cams
I've talked to Bob a few times and He will answer any questions you may have in how the parts work or where the power is best attaned for the $. Good luck.
Old Nov 6, 2003 | 02:00 PM
Choky's Avatar
Default Hot cams
Ok,if I was in Texas or California,I would phone,BUT Im in Spain and it would most likely cost me as much to buy one as to make the phone-call.,LOL.What I really want to know is does it make a big differance? Does it use much more gasoline? And the power it puts on say for example on top,would it take the power from the bottom or would it just add the power without taking it from elsewhere? [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 6, 2003 | 02:26 PM
BigScary's Avatar
Default Hot cams
Ihave a stage 2 and I can't tell that it took anything off the bottom!
Old Nov 7, 2003 | 04:35 PM
Choky's Avatar
Default Hot cams
Forums seem a little slow at the moment,so maybe someone can help me here without missing out on whatever they did before. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 7, 2003 | 06:09 PM
sixsixT's Avatar
Default Hot cams
The more power you make the more gas you use but it's not a big difference. I just put in a stage 1 cam and it added a little to the mid range and a little more to the top but I now have a bog that I can't get rid of doing second gear starts, not real bad but I don't like that part. It would be best to up the comp. when doing a cam to make up for the loss in the bottom end.
I would not put one in if you don't have a pipe, filter and jet kit.
Old Nov 7, 2003 | 06:53 PM
garyc660R's Avatar
Default Hot cams
Bobs member name here is MBRP....MBRP has a furum exclusively as well. Go there and ask Bob a question and I am sure he will respond when he gets a chance. I would tell him I am from Spain as well so he knows your situation and maybe can help there as well.
Old Nov 7, 2003 | 06:57 PM
Choky's Avatar
Default Hot cams
Thanks. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 7, 2003 | 11:27 PM
LimitedEd02's Avatar
Default Hot cams
I want to put a Stage 1 hotcam in my Raptor but..... I'm Afraid to lose dependability. And also thinkg about maybe a different piston[img]i/expressions/face-icon-small-confused.gif[/img]
