Hot cams
Old Nov 8, 2003 | 12:32 AM
sixsixT's Avatar
Default Hot cams
The cam souldn't hurt reliability any.
Old Nov 8, 2003 | 04:51 AM
fast440's Avatar
Default Hot cams
I hvae an xr650 cam in my ex, and it works great, no bogging at all
Old Nov 8, 2003 | 06:49 PM
LimitedEd02's Avatar
Default Hot cams
I also was wondering if I should order a jet kit? Currently I have a White brothers R4 full exhaust. A K&N air filter. I just moved the clips in the Carbs. Runs good now but with the cam Should I Change the main?
Thanks For help[img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 26, 2003 | 06:07 PM
HotCams's Avatar
Default Hot cams
Fast440,
Which 650 cam are you using? XR650L or R?
Choky,
I would only use the Stage 1 in a stock engine. It produces more torque and HP all through the rpm range once a pipe and ket kit are installed.
Tony
Old Nov 27, 2003 | 01:58 AM
  #15
bighonda's Avatar
Default Hot cams
how much does a stage one hot cam set up cost??? lets say i have a stock raptor with a k&n filter, what would i be into with a stage one???? i know i would be getting a a pipe so dont add that in the price. how much horsepower do u add???
Old Dec 1, 2003 | 10:10 AM
  #16
HotCams's Avatar
Default Hot cams
Big,
MSRP is $149.95 for the camshaft. Nothing else is needed for the install other than some Yamabond 4. You're looking at about a 10% increase at peak for the Stage 1. It develops more HP and torque everywhere in the rpm range with a well set-up machine.
Tony
Old Dec 1, 2003 | 02:23 PM
  #17
BigBearFX's Avatar
Default Hot cams
The stage 1 is a drop in cam. It will put you in front of the piped and jetted crowd
will they give you better OVERALL power or just top end?
Old Dec 1, 2003 | 02:25 PM
  #18
HotCams's Avatar
Default Hot cams
The Stage 1 will. The Stage 2 is good for mid and up on a stock bore, stock compression engine. With a 416 engine, it becomes very good everywhere.
Tony
Old Dec 1, 2003 | 06:00 PM
  #19
14mins's Avatar
Default Hot cams
Hot cams- I went back to the stage 2 after a 2 week try of the web 685. Still smiling. I was on Bob's sons raptor saturday with 35mm FCR's into a custom intake. The right intake makes a world of difference. After i got off the raptor Bob's son came over and checked the avenger 2 EGT. Said i was shifting at 8800 rpms. I was still making good power on top. Very impressed. I felt (butt dyno) the stage 2 was making power up there. I thought the stage 2's peaked at 8200 rpm?
Old Dec 1, 2003 | 06:42 PM
  #20
HotCams's Avatar
Default Hot cams
Excellent! Glad to hear (read?) it.
Thanks.
Tony
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
