difference between chains
Old Jun 15, 2000 | 12:28 PM
dondiesel8's Avatar
What the difference between an o-ring chain and a non 0-ring chain?? Which one is better and which one lasts longer??
Old Jun 15, 2000 | 02:56 PM
Brad_L's Avatar
The places you ride will determine what kind of chain to buy. If you ride in a lot of mud go with an o-ring because it actually has small rubber rings in the links of the chain. These o-rings keep grease in the rollers that is injected when the chain is made.
A heavy duty chain is much more simple. There isn't any seals or grease and the links are metal against metal.
Both chains can stretch over periods of time, both chains can kink when not lubricated properly, but the o-ring will probably last longer in really harsh conditions.
Old Jun 15, 2000 | 04:02 PM
Y2K300EX's Avatar
An O-Ring chain will probably last longer, but a non o-ring chain transfers more power (very little). It is all up to how much you want to spend.
Old Jun 17, 2000 | 02:44 AM
hot_shoe_cv's Avatar
The reason you find o-ring chains on most, if not all new quads, is because the low maintainance they require. The rollers are lubricated at the time of manufacture and the lube is sealed in with the 0-rings. Most people who should know say no lubrication is necessary since it cannot reach into the rollers anyway due to the sealed rollers. About the only benefit of lubricating 0-ring chains is to prevent the side plates from rusting. If you have an 0-ring chain you must be careful of what lubricant is used if you do decide to lube it & get a lube made for 0-rings. This would have no petroleum to rot the 0-rings. Likewise, don't use kerosene to clean the chain for the same reason. I use Chain Wax by Maxima as a lube mostly as an old habit from before the coming of o-rings. It just makes me feel better.
This a long answer to a short question, but maybe covers some things you'd think of later.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Steeldon
Sep 9, 2015 09:38 AM
bmark0610
Sep 7, 2015 09:42 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
