Plug spark
Old Nov 6, 2003 | 07:30 PM
dodgepower's Avatar
Default Plug spark
Hey yall I just want a verification if you take the plug out and leave it hooked up to the plug wire. If you lean it up against the frame and crank it you should see a spark between the arm and the element right?
Old Nov 6, 2003 | 07:36 PM
RookWV's Avatar
Default Plug spark
It's better if you just hold onto the plug wire with some fingers soaked in saltwater....
I would think you could do that.....I know I've seen it done on lawnmowers....is this for the 50?
Old Nov 6, 2003 | 07:38 PM
BigBadScrambler's Avatar
Default Plug spark
Yeah, if you ground it out like that you should see a spark. But give Rook's suggestion a try first and see how that works[img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 6, 2003 | 07:40 PM
dodgepower's Avatar
Default Plug spark
Ya it is well i held it against the frame and seen none. Thing that boggles me is thats a new spark plug.
Old Nov 6, 2003 | 08:04 PM
Default Plug spark
You may not be getting good ground on the frame. Try touching it against the engine
Old Nov 6, 2003 | 08:20 PM
trailrider500's Avatar
Default Plug spark
Yeah hold it to the engine, But if you qant to fine out if you have spark the easy way just hold it in your hand "It don't hurt trust me"!!!
Old Nov 6, 2003 | 08:27 PM
dodgepower's Avatar
Default Plug spark
I dont like how you said trust me heheheh and you havent even kissed me hahahahaha
Old Nov 6, 2003 | 08:33 PM
Default Plug spark
Man it dont hurt for real , but anyway how dose the 2x4 scrammy perform? Is it faster than a 4x4 scrammy?
Old Nov 6, 2003 | 08:36 PM
dodgepower's Avatar
Default Plug spark
Mine will get with it. Only complaint I have is I want some more top end. I rarely get stuck like the others say cause i just gas it and let them razrs on the back spin it out of trouble.
Old Nov 6, 2003 | 08:48 PM
Default Plug spark
O yeah you got razrs how do you like then i am thinking of getting some or i might get some holeshots
