Plug spark
Old Nov 6, 2003 | 08:51 PM
dodgepower's Avatar
Default Plug spark
Razrs will kill holeshots all day. I love mine. They hook up great and in muddy situations they clean themselves out better than some mud tires ive seen. I even just have the 4 ply and I pretty much just ride trails. They come highly recommended from this cat[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 6, 2003 | 09:02 PM
Quadman500HO's Avatar
Default Plug spark
It sounds like you have a used plug, simply put it in the plug wire cover. If you ground the plug you should be spark at the plug itself. Once you know the spark is OK, put dielectric grease in the cover before putting it on the plug. This will make it water tight in addition to stopping the plug and wire from rusting, then you will have other intermetent problem with skipping and loose of power.
Good Luck,
Gene
Old Nov 6, 2003 | 10:20 PM
trailrider500's Avatar
Default Plug spark
thanks dodgepower for the input on the tires!!! O yeah i am a Pro rider now!! lol
Old Nov 7, 2003 | 07:44 PM
dodgepower's Avatar
Default Plug spark
Well I was right. I put a good charge on the battery cause was starting to go down but I had tried to jump start it and had plenty of juice to start up. I got another plug today and fired right up after put it all back together. Thanks yall for your help.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
chammerbeck
Jul 17, 2015 08:06 AM
