warrior sputters
Old Nov 7, 2003 | 08:05 PM
oddmetal's Avatar
Default warrior sputters
when i am in any gear and give it 3/4 throttle and then let off the gas, when the rev goes down it sputters out of the exhaust. it only does this once the motor's warmed up.
thanks
Old Nov 7, 2003 | 11:31 PM
Crotts's Avatar
Sounds like jetting to me. Is it like a poping? You could be running lean because of the cooler temp
Old Dec 20, 2003 | 10:48 PM
highflyinHonda's Avatar
Yea it only pops on the way down to idle from a rev. Is there a way to richen the mixture w/ jetting up? It is completely stock...the only time i had the carb off is when my exilary pump spring was sticking. Could it be a sticky valve...if so can i use a gas additive to clean it up?.....thanks
ReconBayou
Oct 31, 2022 05:37 PM
ltrmc02
Aug 22, 2021 02:34 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
